miller
0...you noted on another post, gauge wire was still hooked up...checked sender terminal to good ground----zero'd out..
So, your down to the sender itself. Your also getting a reading. Like I said, I'd pull it, look, and test it's ohm reading. That's the only way you'll know what's going on.Well....im totally confused by now.... i set meter at R1, tested, and now reads 17 ohms...
At least you positively know the problem is the sender. Doesn't mean it has to be replaced! Could be fixed...your call.
