miller
You changed the distributor, but also mention mechanical advance might be sticking? First, never even seen one of the dizzys like you have, but besides the point. Pull the distributor cap, and twist the rotor to see if, it easily rotates, and easily returns back into place.
Just in case you don't know, the main shaft of the distributor, comes up into the capped area. The advance parts of the dizzy ride off a separated part the advance parts mount to, that rotate on the main shaft. Where the advance mech fits on the main shaft needs to be lubed now, and then. Just a hollow shaft fitted onto the main shaft.
Usually just pull the rotor, to expose an oiling felt in the center of the advance's shaft. Couple drops of light oil, unless it's rusted or gummed up. Then, needs to be cleaned up.
Timing chain. Pull all the spark plugs, and using your brandy-new socket, turn the motor by hand to top dead center exhaust stroke #1, and have it there, before pulling the chain. That's where you'll want it, to install the new chain and gears. Main thing is to get the cam set right. If needed, to set the 'dots' right, you can always rotate the motor more.
