- 9:30 AM
- Mar 28, 2014
- South Louisiana
Thanks for the offer, seriously, but I am hoping the electric fan works on the Roadrunner, and I have a couple of options for the GOAT.Got a 7 blade 19 inch not sure if it is GM or Mopar no numbers on it. If you can use it it’s yoursView attachment 1007553
Honestly, I am switching to "last week, crunch time" mode, but I am definitely going to take the Pontiac water pump apart to check that gap between the water pump impeller vanes and the divider plate at some point, probably after CtC, and I honestly hope that's the problem, and I can put that two speed 16" electric fan back on.
IF ONLY my Roadrunner was finished, I could at least compare and if it does fine cooling the 440, I will know for sure it's not actually the fan on the GTO, but the damn thing doesn't overheat with the mechanical fan, but then again, the highway test should take the fan out of the picture!
If both electric fans on both cars fail to cool, I'm going to go off in a FIT OF RAGE (no firearms though) against the fan companies for selling bullshit to the public!
