- 5:10 AM
- Mar 28, 2014
- South Louisiana
I got great news this evening, as there was concern about the space the new RXT dual disk clutch was going to take up, as positioning the hydraulic throwout bearing has been a unique challenge.Git er done!![]()
There are shims and a machined aluminum anti spin spacer that American Powertrain includes with the hydraulic throwout bearing conversion kit. The problem is the input shaft bearing retainer has a couple of "steps" on it towards the case of the transmission. The aluminum spacer and shims do not slide over the first step, and in my case (and others) the spacer alone takes up too much room, which prevents the TO bearing from being able to be spaced the ideal .150"-.200" away from the PP diaphragm springs. The solution was to machine the inner diameter of the aluminum spacer to allow it to move further back towards the transmission. If the new dual disk clutch and pressure plate were much thicker than the one disk unit, I would have a problem.
The great news is I wound up with .127" of clearance, and .100 is the minimum, so while not in the "ideal" range, it is going to work fine.
Once the 541 stroker is ready, I am going to switch to a blowproof bellhousing and block protector plate, so I can address the required space for the TO bearing in a different manner at that time.
I found a shop not far from the shop my car is that knows SPC and aftermarket suspension components that can do a final front end alignment. Thursday is the day, Friday at the latest. That works for me.
