MoparGuy68
Please tell me if what I did today could have damaged my ECU box.
I have an Ehrenberg Hi-Rev 7500 ECU that I bought a couple months ago. In preparation for jacking up the rear end of my car and putting it under jackstands I moved the automatic transmission gear selector into neutral. I did this because I was planning on rotating the rear wheels and counting the number of turns the driveshaft made to figure out my current gear ratio.
I did not disconnect the battery before doing this, which I probably should have done. I turned the ignition key one click forward to allow the transmission to be shifted into neutral. Is the ignition on at that point, and is power going to the ECU you when you do this?
I got occupied examining the wheels when I took them off the car. The ignition key was in this position for probably a good two hours. Then I put the wheels back on, lowered the car on the ground put the transmission in park, and cranked the engine. The engine would not start.. I cranked so many times I lost count. This is the first time since I’ve owned the car I’ve not been able to start the engine. It was getting dark so I have not done the test for spark by pulling off a coil wire or a plug wire yet. Prior to doing all this the car had been sitting for one week, so I know it has nothing to do with carburetor heat soak, or vapor lock. As the engine was cold.
I’m writing this post to check if I have just learned another lesson, the hard way, by ruining my new ECU.
I still have the old made in China ECU that was on the car when I bought it. But I have another problem, with the Hi-Rev ECU that I never fixed after I installed it. When I installed the Hi-Rev and plugged in the wire connector, I then attempted to screw in the securing Phillips head screw that’s meant to keep the wire connector from coming off the ECU unit. That damn screw did NOT screw into the Hi-Rev box properly. And would not TIGHTEN and seat snug like it is supposed to. It just spins around as if the female threaded hole in the box is stripped. This exact screw worked fine with the made in China box and a Mopar Performance orange box. I only had problems with it on the Hi-Rev box.
So now the screw is stuck on the Hi-Rev box and I cannot get it out, therefore I cannot disconnect the wire harness from the Hi-Rev ECU box. The screw just spins in place in both directions clockwise and counterclockwise, not moving forward and not moving backward. The only thing I can think of doing is taking a hacksaw and trying to saw the head off of the screw so I can free the wire harness from the box.
