440 Charger
Still trying to figure out a Spline is that a standard?All 8 3/4" are 30 spline. The diameter steps down from the splines a little and then gets larger, some more than others but I don't think it's year specific.
That was the old way.If you look in the service manual, it requires a specialized tool I don't have and isn't necessary when using the cut and split technique. There is little to no room to get anything behind the bearing to press or pull and they are on there tight.
I'm with 66 Sat....steel then backing plate then foam then axle....but it's been forever since doing a stock set up. Someone is bound to post a pic from the FSMThis foam seal below goes on the axle tube first and then the metal one on top?
View attachment 1142114 View attachment 1142121
Humm go figure it out.This foam seal below goes on the axle tube first and then the metal one on top?
You've just won first prize for the most useless response to a question.Humm go figure it out.
You won the prize for not knowing The question was a joke you dont deserve to have one of these cars.You've just won first prize for the most useless response to a question.
Congratulations! You've just won second prize as well.You won the prize for not knowing The question was a joke you dont deserve to have one of these cars.
Very nice.That's what he's doing![]()
That’s why I’m here! My books are packed for moving.Humm go figure it out.
The question was not a joke. Not knowing or remembering the order of things happens to everyone. Having a forum like FBBO is helping everyone from brand new to MoPar people to older people that have had them all there life. Forgetting or not knowing is not a disqualification for owning a car nor is knowing everything a qualifying quality that is mandatory to own a vehicle.You won the prize for not knowing The question was a joke you dont deserve to have one of these cars.
Pick up the video below @ 5:55 into the video.Steel gasket, backing plate, foam gasket, axle.
https://www.forbbodiesonly.com/mopa...p-new-residence.114133/page-12#post-910739696
I thought it was done in this way. As seen in the thumbnail, it’s the Metal plate, foam, backing plate and then axle type order.
