See post #11 1965 dart gt spring question And who knows what spring length was used. It sounds like some modifications were done.
From what some other members have said the Super Stock springs are shorter thus requiring front hangers that are two inches longer than stock.Sounds like the springs are too short
Just got some measurements back from my Cousin. The front leaf hangers are 5 1/4 inches from front of block to the center of hole. When the car was on the hoist with the weight of the rims and tires stretching the springs out the measurement was 57 1/2 inches and the left spring was 1/4 to 1/2 inch shorter than the right and my Cousin thinks this is due to the right leaf spring having two extra leafs. He said he did short measurements and everything was cemetrical. With the car sitting on the floor and the springs relaxed they measured approximately 65 1/2 on the left side and approximately 65 3/4 on the right side.The stock dodge hangers are about 3 1/4" to the center of the bolt hole. The plymouth hangers will be 1" less. The stock springs have a 22" front segment, and a 36" rear. Most super stock springs have a 20" front segment. E body springs have a 22" front and a 35" rear. Start measuring.
What is shackle fluid?Have you checked the shackle fluid?
Was reading up on the leaf springs and in one article I read it said if the shackles are straight up and down that is acceptable and leaning backward a bit is ideal. I have posted the leaf and shackle measurements in a reply to another member. I very much appreciate everyone's input on this situation.Wrong Springs or incorrect hanger?
Shackle should lean backwards if spring
length and front hanger length is correct!
I don't know if having the two extra leafs on the right spring is the cause of this or if Super Stock springs are supposed to to have more arch however the front hangers measured in at approximately 5 1/4 inches from block to center of bolt hole.If it's the right spring doing this it may have more arch. Think you need longer front perches as others have said.
That's what mine measured in at.I don't know if having the two extra leafs on the right spring is the cause of this or if Super Stock springs are supposed to to have more arch however the front hangers measured in at approximately 5 1/4 inches from block to center of bolt hole.
It's like blinker fluid but for shackles. And you might need a left handed screw driver to open the reservoir.
The first image is of my right shackle and the second my left. The right shackle The right shackle arrears to be leaning slightly more to the back of the car than the left.rsto beWrong Springs or incorrect hanger?
So the correct length of a Super Stock leaf spring for a 1969 Super Bee should be 58 inches?
Using the chart, a stock spring for the Bee is 58 inches. A SS spring is 56”.So the correct length of a Super Stock leaf spring for a 1969 Super Bee should be 58 inches?
That would do it.Using the chart, a stock spring for the Bee is 58 inches. A SS spring is 56”.
My 65 Dodge driver's side shackle with SS prings and 2" extra front hangers. Both drivers side.The first image is of my right shackle and the second my left. The right shackle The right shackle arrears to be leaning slightly more to the back of the car than the left.rsto be View attachment 1556032
With the measurements my Cousin gave me my leaf springs are in between the length of a stock spring and a super stock spring. Besides the length of the spring are there any numbers or other identifiers that will tell you if your leaf springs are stock or super stock?Using the chart, a stock spring for the Bee is 58 inches. A SS spring is 56”.
Per Google search my 440/6 Super Bee curb weight is 3845 pounds so don't know how exact you have to be when ordering springs (example 3800 or 3900 pounds). From your picture example the part number is stamped into the shortest bottom leaf. Do only Super Stock leaf spring part numbers start with a P in front of them?There is a part number stamped on the spring. Google the number to determine the spring.
For example, P3690457 is the left side spring for a 3400# car. The right side spring is P3690456.
P meaning Super Stock?Part number is stamped on the bottom leaf just behind the diff.
Use a 3800# spring; there is no 3900# spring.
P indicates a Mopar Performance part.
Check the part numbers on your springs to determine what springs you have.
O.K. I will assume a Mopar Performance part would indicate the spring is a super stock rather than a stock spring if the part number starts with a P.P indicates a Mopar Performance part.
