- 4:26 AM
- Dec 4, 2009
- Pasadena, Texas
If you don't like the rear being that high, install lowering blocks but man, 5" higher than stock is a LOT!
Yes. The super stock springs for b-bodies are actually a-body length (front section) leaf spring with extended front leaf spring hangers (to reach the shorter springs) & those hangers have 2 sets of holes. One set of holes is the stock location. With super stock springs, the rear end goes WAY up. You can use the other set of holes in the extended front shackles, which does lower the car down in the back, but it changes your rear end pinion angle a lot.What do you mean by replace the rear spring purchase? The front spring Mount is stocked so only has one bolt hole, are you talking aftermarket front mount?
Never heard of the brand 'Superstar' springs.....unless you mean Super Stock springs. I don't like them one bit and will stack my own springs to make them work and keep the back end down instead of it looking like a stink bug. Are you drag racing the car??I'm thinking about 3 in. The Superstar springs raced the back about 5 in. Way too much rake for a four-door
I guess the new guy Todd has never aligned a front end.Technically yes. Ride height is the first setting in an alignment. How much are you changing it?
Poster said should the alignment be redone with a ride height change. So to honestly answer the question the answer is yes. Fluff it any way you want.If you're going by the book and doing a stock vehicle, setting the ride height may be correct.
Who here has a stock car? Maybe half of the members at the most?
Every time I've had a vehicle aligned, they are told to leave the height alone. My truck has 2" drop springs. They play to the lay of the land there so why not with the cars?
I set the ride height to what I want. I'm not competing with the car at the Nationals. I don't care what the stock height is. I don't like any open space at the top of the tires on my cars.
Not so easy with the Dart since the front wheel opening is so high and the rear so low...
The Duster is even harder to get there:
Is that why Disney World terminated you.I'm not a fluffer, man....
SLANG DICTIONARY
fluffer
[fluhf-er]
Despite what it sounds like, a fluffer isn’t someone who stuffs toy animals. A fluffer is—or at least is said to be—someone on a pornographic film set that keeps a male performer erect in between scenes.
That may be how YOU spend your free time but I have no interest in that...at all.
Is this Jeopardy???????????????????..............................You have an issue with punctuation, don't you?
Questions end with a question mark, not a period.
Never heard of the brand 'Superstar' springs.....unless you mean Super Stock springs. I don't like them one bit and will stack my own springs to make them work and keep the back end down instead of it looking like a stink bug. Are you drag racing the car?? Originally was going to but things have changed. Physically unable to change them now so I guess I'll live with it
I believe I will lower the back end one way or another. Thanks for the advice guysI'll add that in my experience changing the ride height without a re-alignment didn't cause the car to handle noticeably differently, but when left that way for long enough did show uneven wear on the front tires. I'd say watch out for that especially if going after (yikes) 3 inches...
PERCHWhat do you mean by replace the rear spring purchase? The front spring Mount is stocked so only has one bolt hole, are you talking aftermarket front mount?
