PurpleBeeper
I’ve got a 70 Road Runner OEM power front disk car. I’ve already switched to ‘74’ish A-body disc front spindles & ‘73 1-piece rotors. I’d like to do the “Cordoba swap” on a budget and switch to 11.75” rotors (I have 15” factory steel wheels).
What cars/years should I find salvage yard caliper brackets from? I see references to pin-type calipers (like my OEM ‘70 single-piston) are preferred, but the pins are hard to find (?). I see Dr Diff sells aftermarket slider calipers/brackets. Thoughts? I will be getting part store calipers and rotors, so what year Cordoba/motor should I specify? I’d also like to upgrade my master cylinder with a parts store one….I see the ‘71 power disc master cylinder has a 1.03” piston (I think my ‘70 has a 1.125” piston). The ‘71 master cylinder has fender-side fittings like my ‘70 does. Both are 4-bolt. Can I just swap in a ‘71 disc master cylinder? THANKS FOR ANY ADVICE! and remember….budget
