Alignment
Bbody4speed
8:14 PM
Ontario Canada
I recently purchased a 63 Fury and it needed a new right lower ball joint. I also replaced all tie rod ends and the torsion bars. Can someone please help me out with alignment specs? The car has a 413, radial tires and manual steering. It goes in for the alignment next Thursday and I would like to provide the desired specs to the technician. Thanks.
See if you can get hold of a factory shop manual for your car ,
It should be covered in it.
You will want different camber and caster specs than what is in the service manuals because of radial tires. Check out @Kern Dog 's posts regarding the subject.
Disregard the listed specs. I do mine at -0.5 camber, as much positive caster possible, 1/8" toe-in.
Shoot for these numbers. If you are using stock upper control arm bushings you'll just have to get it as close as you can.
