fullmetaljacket
- 12:24 PM
- Oct 15, 2010
- Brooklyn, New York
This is what I found in cylinders #1 and #3 after a few modest outings around town including a couple of full throttle bursts. But for the most part, was mostly low speed idling and street cruising. Not enough room in this city.
I might first have to lean out either my fuel mixture screws on the blocks or lean out my idle bleed jets by a step or two.
No A/F metering gauge on board.... YET!
12.5 compression.
SR aluminum heads, VP C12 fuel. NGK BCP7ES plugs. stock number #5030. 35 gap. MSD 6AL Ignition. Firecore CD coil. Firecore 8 mm wires.
Just changed my oil and installed new plugs as per ThumperDart suggestions. His carb is awesome throughout the pull and upstairs, but a little rich on the idle circuits. Trying to find time in between to tune with good mine shaft air now hovering over New York.
12.5 compression.
