fullmetaljacket
- 1:40 AM
- Oct 15, 2010
- Brooklyn, New York
Thanks for verifying that D.Mine is heavier than a tin pan for sure.
Yes, but it really does depend on the type of aluminum pan though. A cast aluminum pan is indeed much heavier than stamped steel pan, but a fabricated sheet aluminum pan can be the lightest in some designs. I know that my aluminum sheet transmission pan is lighter than all the ones I have had on before.I ran into the same situation with transmission pans. I kept the factory steel deep pan because it was lighter.
It all depends on what type of aluminum they are made of. Those lug nuts look like they have some other metals inside which could mean that they are strong. Did you purchase them from a reputable circle track/race shop outlet?OK, just for kicks, I bought a bunch of OE style aluminum lug nuts. They are 1/2-20 w / 3/4" wrench size. These are stupid light, so much so that I am afraid to use them,
That is 1.07 OUNCES for a set of 5, or 0.216 OUNCES each.
Like I said, they are scary light
They look sweet and should be fine, but it doesn't hurt to know what they were cut from.I did buy a set of the same aluminum lugs you pictured. Those things are really well made. The ones I pictured were just an ebay item I saw. I sent a message to the seller asking if he knew what type of aluminum they used (they were made in a New Jersey machine shop).
6061 is strong.OK, those OE looking lugs are 6061 aluminum. I might give them a try. I also have similar looking lugs in titanium, so I am covered whichever way I go.
No. Its properties are not suited for water stoppage.Quick question, will antiseize seal against water, like say...exhaust manifold studs?
Asking for a friend.......
White Teflon paste sealer is your friend for this application.Quick question, will antiseize seal against water, like say...exhaust manifold studs?
