Sales codes for 1970
nes4pres
10:47 PM
CANADA
I am viewing a fender tag, WM23 N0A. I believe this to be Coronet, medium (Superbee), two door, 383, 1970 in the Lynch Road plant.
The second line codes at the TOP of the fender tag are 083 051 663. I am told these are historical sales codes before 1970.
Does anyone know what they decode too?
083 engine 051 rear axle 663 trans
(663 is really 668 on the tag for automatic 383-4bbl)
Those are from a Lynch Rd produced car. But yes, they are the driveline numbers.
083=383-4bl?
051=Rear axel. Does it decode what gears and what axel?
668=automatic. Does it decode to floor or column shift?
C16 on the fender tag would be for center console (and a woodgrain panel).
051 for a St. Louis '70 Charger would be
for a 383 4 BBL AUTO 8.75 AXLE 3.23:1 RATIO
I would "think" it would be the same for Lynch Road?
668 will tell us what trans it is by part number, nothing about a shifter.
If the interior code is for a bench seat then you know it's a column shift. If interior code is for bucket seats then it could still be a column auto.
Yes C16 should be on there if it had a console.
Can you post the tag photo?
18144 207119
083 051 668
V1X N96 L31
EB5 M637 Eb7
E63 D32 WM23 N0A
If you won't post it I will.
And yes C16 is on this version
M6B7 = bucket seats in dark blue
for the 051 axle, I've got front disc car, 8-3/4 axle, 3.23:1 open, 10 x 1-3/4 drum rear
668 = PK3410668 a727b automatic
I don't have reference for that specific engine code
Edit note - The engine and axle numbers are part/assembly numbers used on the production line... not "catalog numbers" for counter purchase.
2nd edit: I'm going with your engine assembly being 088, not 083. A pic of the back of the tag would likely tell all.
088 - 383/4, auto, no a/c, orange HP, 335hp 1970 carb 42 trans 668
I believe your carb should probably be the Holley (broadcast sheet 65) because of N96 Ramcharger/Fresh Air
