Shaggyracer
Hello everyone! I just got my 1974 Charger painted and I'm starting to get her put back together! I'm starting with some weatherstripping, and I'm curious what y'all recommend for adhesive?
And the leading edge of the door jamb weather strip.The only weatherstrip that gets adhesive is the trunk.
That's assuming he has either all new or old with all the pins. Plus there are many other areas that will need a taste of the 3M.The only weatherstrip that gets adhesive is the trunk.
I have the replacement weatherstrip for the doors, but I'm curious what adhesive to use between the door and the weatherstrip channel?And the leading edge of the door jamb weather strip.
Could you tell me what to use on the metal between the door and the channel for the weatherstripping on the doors? It's metal to metal and I can tell it used to be glued/taped?That's assuming he has either all new or old with all the pins. Plus there are many other areas that will need a taste of the 3M.
There is a foam strip that goes there. Mopar B Body 71 72 73 74 Weatherstrip Channel (Drip Rail) to Roof Sealing Strips Rolls
