Gigi rides again - with some issues
subforry
7:12 AM
Hermosa Beach CA
Hi all,
After a long time and many upgrades, I have final got to take my '66 Charger for a long and highway shake down.
After many anxious miles on the freeway with the temp gauge about 1/8" from too hot, I pulled off, ready to burn my finger tips opening the hood. But nothing. It was not hot. I think the temp sender has been the wrong one from day one or I put the wrong one in there. What is the proper temp sender for a 440 with factory temp gauge? My wiring connector is the slip over thread type.
Next, the idle speed screw is in too far and it's too far off the idle circuit - I'm getting vacuum on the ported hookup. If I back it out, the idle drop way too low, and dies. The mixture screw have some effect so I think the idle circuit is working. Timing is by ear where is runs the fastest and smoothest. It's a '78 440, AVS2 800, Edelbrock heads and intake. I think this was not a problem before new heads and intake. The EGR port is connected to a valve cover breather, no PCV. The brake port (back of carb) is blocked, the brake booster is connected to the manifold.
Finally, I just learned that 440 cast cranks are externally balanced. In the freeway, the car has a rhythmic drone that rises and falls. The faster I driver the faster the drone rises and falls. If I let off the gas, the drone stops. I have the drive shaft rebuilt and balanced. Does this sound like an unbalanced engine? I think my crank damper is from the original 361 engine and maybe not from the '78 440. See picture.
Thanks.
Cast cranks are external balanced. So if your motor is in fact a cast crank and thats the balancer it will vibrate. Plus you also most likely have the wrong converter. Can you say vibrate?
Correct me if I'm wrong, but if it is a cast crank with that balancer, and possibly the wrong torque converter, you would know it! At highway speed it will vibrate.
Definitely a steel crank balancer. If you also used your 361 torque converter, it is not balanced for the cast crankshaft. Note that a later converter meant for a cast crankshaft will not work with your small input shaft 1966 727, either. Continued imbalance will be detrimental to your engine.
RE: vibration/droning noise, I read this page and lengthy post on balancing. Harmonic Dampers 440 Source.com I have no idea what the converter came from, this is all PO stupidity. I guess a first, and kind of easy, step is get the correct damper or I see that 440 source has a counter weight that can be added - maybe.
Thanks.
Thanks.
Do you know for sure that the crank is cast? Just because the block is a 78 casting does not mean the crank is cast. Someone may of built it with a forged crank. You need to verify the crank and that should be the first thing to know. Second step would be to identify the torque converter. You already know the harmonic balancer is for a forged crank.
I'm looking at the temp issues on a 69 B body right now. As best I could find the "correct" temp sensor would be TS17. I tried another one that was listed and it barely moved the needle. IIRC the resistance was higher than TS17.
TS17 seems to read about mid scale at 200 degree looking at the engine sender in the pump housing via an inferred gun check.
The TS17 is what I have, it has the correct connector but reads high in the '66 charger. I have ordered a TS18, wrong connector but I think it will have the correct range
Updates. The intake manifold gasket was leaking, sucking oil into the intakes. It was my mistake, manifold and heads fit very well, so I thought the valley pan could be installed dry. It been reinstalled with sealant. Now the idle speed screw is about correct.
Another thing I learned is about breathers and PCV. I had a tight fitting oil cap on one valve cover and a breather going to the carb PCV port. I felt air flow at the carb PCV port was not enough and the engine speed would drop when I connected the breather. Now I plan put breather on one valve cover and a PCV on the other, run that to the carb.
A "bullet" style damper is in the mail. I choose this one because it's correct for the year of the engine. It was not clear if the all 440 couter ballanced dampers have the same weight offest.
It's comming together, but man hot rods are a pain.
Ok, the upper one came off and the lower one is installed. Seems better at idle but I haven't driven the car yet. I am pretty sure the stumbling at idle is too much fuel pressure, it's 6psi on the Edelbrock AVS2. So next is a fuel pressure regulator and then I will check the float level. More to come.
Usually off idle is not enough pump shot or lack of advance timing. 6 psi should be fine
Wow, what a difference the correct crank damper makes. So smooth and the rest of the car isn't rattling. Ok so that is fixed.
I installed a fuel regulator because it wouldn't idle with the PCV connected. I think too much fuel was getting dumped in the carb and it needed the extra air from the open PCV port. With the fuel regulator at 4psi, I was able to connect the PCV and retune the engine. The idle speed and mixture screws are withing reasonable settings.
Now I need to figure out the idle stumble. In gear (it's an automatic), the stumble feels like the engine is going to die and the car suges. The idle rpm is about 830. Idle AFR is 13+. Even if with the idle at 1000rpm it still stumbles and feels like it will die.
There passenger side tick that could be a lifter problem. This could be the stumble. I will pull the valve cover and crank the engine, and check the lifters. Also use a temp gun and try pulling different plug wires, maybe pull the plugs.
Can you get the idle lower?
It should be around 650 rpm.
The stock converter on mine was really tight so 800 or more it would try and pull in gear idle would drop and affect the vacuum advance.
Good idea. I will give it try. Yes, the converter is ridiculously tight.
I'm still skeptical on the fuel pressure question.
Have you checked the float setting?
6 psi should be fine.
The pcv vacuum leak thing seems very odd.
Has the converter been checked for weights by the drain plug yet?
Given that my gauge was cheap and now not working, it could have been more than 6psi, either way I will do more investigation. I should be able to check the floats in the next few days.
I tried lowering the idle speed. It barely ran at what I think was about 600rpm and dies when put in gear.
This got me to thinking about the cam and what idle speed would be needed. The specs are attached. The timing set has options, I took the neutral one (dot to dot?). Rockers are '78 440 or off 516 heads. Stock block and pistons so the comp ratio is less than 9:1. The upper end is Edelbrock power package.
Thanks for all the help.
