Superfreak, thank you for the welding complement. I don't see as well, as I us to, and every now and then, my wire welds look decent.
Ckessel, when the spring relocation kit came in, it had the wrong size insert sleeve (shackle end) for a B body. An A body insert sleeve was shipped with the kit. The A body insert sleeve is to small for a B body shackle bushing. Picture:
The insert sleeve on the left side of the picture is an A body sleeve. The one on the right is a B body sleeve. Unfortunately I had already cut the hole in the frame for the A body insert sleeve on the left before it was realized that something wasn't correct. US Car Tool made good on the this little issue and I enlarged the hole in the frame using a rotary file.....
The rear spring relocation brackets have been tacked into place and the rear spring installed to check fit....it looks good to me:
The rear spring perch's welded out...
Next on the list, mini tubes...I must have just fallen off the turnip truck, I haven't a clue as to why I didn't get both the spring relocation kit and the mini tub kit at the same time.....an order will be placed with US Car Tool for their mini tub kit.
Miller, I wouldn't fret much about the hood fitment.....most people will never notice it unless it is pointed out. I was concerned about the gap between the fender and cowl top on my car....it is pretty big on one side. After going to a car show yesterday and looking at Joe Suchy's factory 1964 sport fury it too has this large gap on one side and not much of one on the other....
