This is why you never throw anything out. Old aged clip with one end that is missing a usable tab, so I cut the good end off.
Popped that good end into the retainer hole to hold the broken clip back in place and then some Gator super glue.
All fixed up and you'd never know one was broken if I hadn't told you.
Figured I may as well use the rest of that clip I cut to fix the most forward one. It still had the "stud" in the hole but was missing about 3/4" of the body.
Glue to the "stud" edge and the overlap and clamped with hemostates for a few minutes.
Back to functional and again unnoticeable repair beside the battery.
Installation now looks pretty neat and it's going to stay as is. Interacting with other '66 Hemi owners here on FBBO has determined that the reverse / oil wires do take the short cut under the master cylinder. Possibly not exactly the way I have it, but it's close and functional so we move on.
Installing the tachometer I got from "Santa" before Christmas, so I can get a real comparison on RPM vs the sound of the beast... so I don't blow it up! Once I get use to sound vs RPM I'll probably take the tach back out.
Was nice that the last owner simply cut the wires from his tachometer install and taped them all together to be found up under the dash. All wires still hooked up to power, light circuit and ignition coil.
All hooked up and it works. Just waiting for the worm gear clamp to dry after spraying it with black trim paint, then I can clamp it to the steering column.
