Some more updates:
Removed the window wiper shafts.
They were not easy to move so i soaked them with WD40, after some moving around they came more free and now are very easy to move.
Got new seals on them and put them back, installed all the wiper bars.
The last time i bench tested the wiper motor i set it in the park position, saves guess work when putting the wipers back on the shafts.
Installed the heater box again, which was easy enough.
I did notice the tubes for the heater core do not stick out of the fire wall that far as the old ones.
I might have to pull them out more a bit to get the hoses installed properly.
Some time back i remember reading someone had issues with installing the hoses, when trying to push the hose on the brass tubing just bends.
Need to figure out a way to hold the tube and install the hose at the same time....any suggestions?
After all that got the dashboard back in place, this was also sand blasted and painted in matte black.
I reinstalled the fasteners which hold the upper section near the window in reverse, the clips are attached on the dash board and the screws went in from the bottom.
This way the dash can easily be removed in the future without removing the front window.
Installed the Under Dash Wiring harness, very easy to work out what is what and to find a good way to lay it out.
I found my old harness had an extra part that was not supplied with the new one, which is for the map light and the glove box light.
When removing i did not find any brackets etc. for the glove box light so guess i will have to find something for them.
If i am not mistaken with this "light package" there should also be a light for above the ignition key right?
There was nothing there either like a bulb socket or whatever but i can maybe find something for that and integrate it into the "light package"
Still have some additional wiring to do for the radio and the additional gauge cluster.
I cut the connectors of the Amp meter and soldered them together and installed 3 layers of crimp sockets, good for resisting 600 Volt.
I will also run a bypass in the engine compartment as well as many done before and recommended this to prevent potential disasters.
I will run an additional wire from the alternator output and hook it up direct to the battery terminal, bypassing the fire wall connectors.
See below some pictures.
View attachment 537422 View attachment 537423 View attachment 537424 View attachment 537425 View attachment 537426 View attachment 537427 View attachment 537428 View attachment 537429 View attachment 537430 View attachment 537431
