It beats the snot out of Budweiser!i also want to recommend, there are far better beers out there than rocky mountain goat piss.
I'm a tool maker and they do make shim stock down to .001, maybe check somewhere else. You may have more difficulty trying to cut the spring steel. Might be worth the time and effort to just order shims in the sizes you need. Or visit a local machine shop. I would think they could set you up.
Remember with alum heads your cold lash could be different than steel heads. I'm sure someone with stealths could give you a starting #. My trick flows are .010 & .006 cold.
so it whats left to get on the road? just stick the motor in and fire it up or is there still a laundry list of to-dos like wiring and lights and stuff?I'm setting them .008" exhaust and .006" intake. I finished lashing them last night, no issues. Everything looks good. I still need to pull the heads to inspect valve clearance and remove the playdough. Also getting my oil pan gaskets so I may have the motor buttoned up by this evening.
I haven't decided. What would you recommend for a street car? Looking around the 800 to 850 cfm range.I see you are going with a spreadbore intake, which carb you going to use?
I'm not sure I can make a good recommendation. But I did like the old big Thermoquads. Great mileage and BIG secondary's. I do like vac secondary's. I thought I saw Demon or someone came out with a Thermoquad replica. 850 -950 would be good.
Quick fuel makes a 880 vac sec but it's a square bore. 575$
