The Beep
- 7:24 AM
- Feb 15, 2013
- Williamsburg, Ontario
I just went and snapped a few pics from my 68 Roadrunner. It has a NEW Year One 1968 engine harness (same as yours I believe), the mechanical voltage regulator (same as yours I believe) and the 70's era Dual Field Alternator (also the same as yours I believe).
This is a picture of the Voltage Regulator:
Looks Like yours.
Now here is MY Dual Field Alternator:
The large black wire (I have two due to an ammeter bypass mod) goes to the BAT connection, yours looks right.
It may be a little hard to see but the factory Green (with black tracer) wire goes to a Field connection, either one.
Finally is the CUSTOM Yellow wire on the second FIELD terminal. It is a simple "jumper" used to ground the alternator's opposite end to create a completed circuit. Its a little hard to see but one end is connected to the FLD connection and the other is simply bolted to an unused bolt hole on the rear of the alternator (any good ground).
I have run this setup for years and it works well. If everything else is good this should be it.
Good luck, and regardless of the thread title I don't want your money.
Looks Like yours.
