Chris Many
- 6:37 AM
- Aug 20, 2018
- Highgate Falls, Vermont
much appreciatedWow looks great Chris many ....glad to be a small part of this project
I have had countless mopars and have never seen a block 'repaired' by the factory like that. It was probably done by someone over the years. It looks like epoxy?UPDATE 6/13/22: I finally for the engine in paint and will be installing it in the next couple of weeks. Here's a few points of interest.
1) No big surprise, when I took it a part the nylon coating was missing on a lot of the timing gear teeth, so it probably didn't run very well and that may have contributed to the car being parked forever.
2) One big surprise was that the block had been repaired by the factory (middle picture). I was told by the machine shop that they see these kind of repairs on perhaps 1 out of 10 old Mopar blocks. Not sure how true that is, but mine obviously was factory repaired as the heads had never been removed. The repair looks decent, but the area was ground down a little too low. Had to add a little sealer around the head gasket in that corner. I'm sure there was an oil leak in that corner before.
3) If it wasn't for the fact that I had restored another 1970 318 (on my FM3 Challenger), I would not have noticed that the top right (left in this picture) bolt on the cam thrust plate was not correct from the factory. That bolt is supposed to have a hole in it so that oil would drip down onto the timing chain. Did this lead to the timing gear damage ? maybe. anyways I didn't have the correct bolt so I drilled a hole down the middle of it.
The repair was done with nickel. here's an underside shot. you can see the spatter from the welding process,I have had countless mopars and have never seen a block 'repaired' by the factory like that. It was probably done by someone over the years. It looks like epoxy?
Interesting. It could have been done at the foundry, but again, I've never seen this before. Usually any casting issues like this, the block gets recycled by the foundry but who knows for sure? Very unique at any rate.The repair was done with nickel. here's an underside shot. you can see the spatter from the welding process,
Very cool. Live the color and originality you are doing. Looks like day one. I'm installing engines the same way. I have a cart already that I will modify. I saw that company's stuff and it is excellent. I'm ordering roof rail weather strip for mine.UPDATE 7/25/22: The engine is now installed and I am almost ready to put on the front tires. I installed the engine semi-factory style - from below. I found it is easier to leave the carb off (which is out for resto) and roll the engine under the car rotated 90 degrees, so that I didn't have to jack up the front end as high. Once under the car I spun the engine around, lowered the body down and then used a couple jacks and some blocks of wood to raise the engine/trans up into place. Took me about 2 hours.
In the last picture you can see an original style oil filter (green with sandy texture and raise "M"). I installed it just for the pictures.....
