1970 Plymouth Sport Satellite from Junk to......
The interior rear top metal door panel used staples to attach the whiskers. After some thought I decided NOT to attempt to use staples. I think without the right heavy stapler and backing it just wasn’t practical. So I decided to deviate from Chrysler and use rivets. I used a 3/8 rivet which was just right. Works well as they sit below the whiskers and hold extremely tight making this an ideal alternative.
So it begins…… Front end rebuild.
You bitch you lol! Ok well map gas, penetrating oil the right tool (btw the size I used is 1-59/64) and ultimately an impact to loosen it. I was bending my breaker bar and thought it better to possibly damage the threads of the upper ball joint than bang the new paint or worse **** myself up.
I bought the proper A, B, E and C body ball joint sockets years ago in the early 80s. I still have them, they work great for pressing bearings on and off with the press. Lol.
I removed the UCA’s and had the alignment shop R&R the ball joints, it was cheaper than buying the special socket.
Best find on amazon yet that’s pretty cheap for as often as you use it it..
Tuning up my Lower Control Arms. One had some slop in it. Actually a lot (~1/4”) on the drivers side for some reason. So I ground out one side of the joining tab and brought the assembly closer together to remove any slop but yet let it move freely. The re-welded the plate. Boom done.
Time to weld on the sway bar tabs then sand blast them.
