1971 Sway bar bracket shape
SMS68
7:47 PM
Oklahoma
My 71 RR’s original sway bar brackets both appear to have bend in them…not a clean u shape. The replacements that came with my front end kit are a clean U shape.
Are my originals bent or were they supposed to be that way?
Bent from hitting something.
Crazy thing is they are both shaped identical and leaning forwards…not backwards, as you would expect if something was hit
Are the new ones a thinner gauge?
Ordered some correct ones. The ones supplied with my rebuild kit didn’t work at all. Bushings were too wide to even fit in the mounting channel and the brackets were too shallow.
Maybe slightly thinner, but they were also shorter so they won’t work. Ordered a correct repro set today. Should’ve gone that way in the first place
