The Capitan
Wire nuts?
None of the above....someone mentioned nichrome wire....which alloy?? The common type is 80/20 % nichrome (nickel/chrome) but did you have a specific alloy in mind?? As they have different resistive characteristics and respond differently. ....just curious.....
BOB RENTON
THANK YOU FOR THE INFORMATION......Alloy 675 (Nichrome 60)
(Nickel: 60%, Iron 24%, Chromium 16%)
Was frequently used when moisture was prevalent, subject to more severe use and operating conditions..
Just my $0.02...![]()
I'm chasing a no start when cold issue with my converted Mopar Electronic system. As soon as I get my ECU and pick up from halifaxhops, I hope I get it working. If not, I'm going back to a points style distributor with a Pertronix Ignitor I. Simple and usually trouble free. I don't need anything high performance or mega volt. Just something that is no maintenance and works. Simple and effective. Oh and the Pertronix works up to 16 volts. @pedal2themetalHI,
I think I'm just going to go back to stock stuff with new ICM , coil and resistors. On the duel resistors How do I know which is which and which wires to connect to which in case there are wrong now/?
Replying myself.I already did, but with one MJ00005 transistor (the closer I could find, just to test for the fix) which was one I found at a local electronic shop in Venezuela. I just made the pot cut on transistor area and got success getting back to life the Module. Just need to replace it now with the NOS MJ00012 I found on eBay later.
The MP box is one of the laters one, so the potting was pretty much solid… and it was more like a rubberish compound.
For my build I preffer to keep the stockish system as posible.
