That almost sounds like "make believe"...a 5.57 gear
EEK!!Stage 5 heads that flow 540. The motor made the most HP on the dyno at above 8000rpm
I'm not sure if I've heard of a ring and pinion over appx 4.86
WOW!
EEK!!
The Hemi car has a 4.56 gear with 32" tall rear tires.That almost sounds like "make believe"...
WOW!
EEK!!
I never reported that the motor is a legal SS motor.Hey Mike, does this engine have a dyno sheet?
With Stage V heads that's not a legal SS engine.
Most I've seen with Stage V heads stopped pulling at 7500 RPMs.
It may not be a "legal SS motor" but it is "legit"! 2 legit to quit!...I never reported that the motor is a legal SS motor.
Wow. That's a bold statement about someone else's car, that Mike has already taken through a shakedown at the track, and Mike sounds pretty confident in his expectations, and he certainly has a LOT of drag strip and MOPAR experience...I guarantee that hemi wont like anything over 7500 rpms.
Curious why you say Hemis won't like to run over 7500 rpm? I've never run one that high. Read, for what its worth the Mopar Missile came off the line at 8800 rpm.Mike, I was just asking if it was a SS Hemi.
Do you have a dyno sheet or did the seller give you that information?
I wonder if you got Millineum hemi heads.
How much HP did it suppose to make?
Maybe it didn't pal. You didn't answer the other question.The Mopar Missle did not come off the line at 8800 Rpms pal.
He seems hostile for some reason?Maybe it didn't pal. You didn't answer the other question.
This guy sound like he has been racing a long time and must have 4 race cars.Post up some of your MOPARS,,,,,TomWow. That's a bold statement about someone else's car, that Mike has already taken through a shakedown at the track, and Mike sounds pretty confident in his expectations, and he certainly has a LOT of drag strip and MOPAR experience...
Why so seemingly negative about what Mike expects from this combination?
