3/8 or 1/2 prebent fuel line?
robinsonwr
3:07 AM
Carriere, ms
Does anyone know where I can buy prebent 3/8 or 1/2 fuel line for 1966 Satellite? I need to feed the stroker under the hood. I appreciate any and all help, thanks.
Fine Lines is where I got mine (`66 Blevedere II...same car). Removed the original and laid them side-by-side to ensure I had the correct line. Note: They have to ship it with a 'U' bent into it. The 'U' is marked with tape and easy to remove. For the most part it went right in. Maybe a slight bit of tweeking to eliminate any chaffing points.
Will a 3/8 line support a pump gas 512/440? The car is not a drag car it will be a street car with the ocassional blast at the track.
it will you'll just have to make sure your sending unit is 3/8" as well
