Dave145
I did not try the compression test again. I may give it another go later this weekend because now of course it's raining up here again. I'm not too happy with the 90PSI either. But being that the oil in the cylinders didn't increase it much, that tells me it's gotta be bleeding off somewhere!
I've never water misted this engine (though that would be a good idea). I have seafoamed it in the past with excellent results though. Thing smoke out an entire industrial park at 1AM! It's been awhile since I did it, so I may give that another shot again. I just let is get I inected into the engine through a vacuum hose and then let the car sit for a little while before firing it back up.
The heads are a bit sludgy but it's really not all that bad considering the age of the car. I've never run a flush of any sort through the oil because I'm afraid of either dislodging enough deposits to plug something up or wiping out a bearing somehow.
The car has somewhere around 80,000 miles on it and had been severely neglected. It sat in a field in TN for 20+ years untouched. I wasn't lucky enough to be the one to drag it out and bring it back to life, but I've slowly been fixing everything that time has so far degraded.
