2quick
I'm the guy that sold you the motor. Sorry I didn't chime in, I just found this post. If you still haven't straightened it out yet check the throttle shaft for a vacuum leak. If the carb you are using is the one that came with that motor, I machined the carb base plate, and pressed in oil light bronze bushings to try and fix a pretty good vacuum leak on the worn shaft bushings. After I was done it was much better but not perfect. Also the MSD ingintion module I gave you, requires you to bypass the ballast resister on the fire wall to feed 12 volts to the module full time. Let me know if that helps.
Also like I said before if you still suspect a trans issue, I have the one that came off the motor that worked fine. Just come pick it up.......
