Tempest 455
Just a few thoughts for the OP:
Sounds the reverse but very lean will give you a worse eye burning sensation. Rich will as well but honestly, a very lean idle condition will make your eyes burn and clothes smell like you will not believe. Its called a lean misfire. Typically its a result of the retarded timing, people crank up the idle speed past the idle circuit and it' now idles on the primary circuit w/ no idle enrichment. You will know for sure if your idle mixture screws do nothing.
Regarding aluminum heads, (another makes but same principal) I installed some on a car about 15 years ago in place of some ported cast iron heads. Car went .40 quicker in the 1/4 w/ just that change. New CAD designed port shapes, valve work etc. will be a vast performance improvement over most factory stuff. The increased flow and ability to run more compression are significant benefit. Just depends if you want the car to be stock or not. Some cars I would do this, others I would not even consider it.
I built a motor for a buddy a few years ago and we painted the Al heads and even made casting #'s using epoxy.
I swear it's just a "stock" 400! ;)
Well maybe around 70 ci more and a few other things.
