99ss
Lot of interesting responses in here.
Blue printing the engine doesnt do a freaking thing to add power..... Yes its nice to say it was built with precision.. balanced and blue printed. It will add to longevity but as far as a power option it is not... Although I will say my builder says he picks up 15 hp over others because they dont align hone.
Yes you want to deck the block per the piston to get proper quench .. This will help with tiiming and detonation IIRC
You want the best flowing heads you can get... I am not a mopar engine expert at all so I cant tell you what heads those are going to be but they will need to be ported and polished.
The cam is obviously going to be big. An engine is air pump.. More air in more air out more power made.
If it was a Chevy Ls1 383 it wouldnt be an issue to make 500 at all.. quite simple really.. power is made in the heads and those engines can run 7k rpms all day long. SO the valve train would be a good place to put money as well. Valve float isnt going to help you at all. 3" exhaust ( dual) and at least and 850 carb with a dual plane intake.. Eddy rpm air gap port matched and hog out where you can.
EFI or not doesnt really matter I dont think.. its only 500 hp
