Curiousyellow71
I know it's nice to buy a piston that drops in...But depending on whether a piston has a solid or hollow dome...it is possible to remove part or all of the dome...get the compression EXACTLY where you want. That is making the assumption that the dome is removable. Some are...some aren't. Occasionally you can pick up some very expensive pistons that no one wants because the compression is to high and just shave the dome off turn them into a flat top. Shaving domes and flycutting valve releifs...both have some cost..but often necessary.
