BearDodge67
Here's a question... what's the gearing in the car?
It's 3.23. The car is meant to be a cruiser. It's reasonably quiet and has AC, PW, PB and PS.Here's a question... what's the gearing in the car?
Never trust what 'dead on' is.....always degree the cam then you know exactly where things are. Heck, I've found 'stock' cams to be off enough to make a difference in performance. A buddy of mine did a performance cam using the 'dot' method and got screwed with all of his new exhaust valves getting bent.Only the springs, spring height as per their specs in the catalog. Checked the cam and it was dead on going straight up, so didn't have to degree it. Don't know what cranking psi is, never checked.
That power range will give it some serious bottom end grunt ...It gets better: After concluding I could not trust anything verbal, I pulled the cam and it is not even what they said it was (10230703). It is 10230700... what Lunatti calls an improved HP, improved torque, ski-boat, towing cam. Specs are reasonably close to a stock 440 HP cam at:
208/213 @ .50, .454/.452 lift, 112 LSA, 0-5000 rpm range.
It'll work. I was even able to save the gasket. Done and moving on....
Thanks all.
Is the cam degreed in?It gets better: After concluding I could not trust anything verbal, I pulled the cam and it is not even what they said it was (10230703). It is 10230700... what Lunatti calls an improved HP, improved torque, ski-boat, towing cam. Specs are reasonably close to a stock 440 HP cam at:
Thanks all.
That's good to hear. That will work well with what you have. How do the pistons look?It gets better: After concluding I could not trust anything verbal, I pulled the cam and it is not even what they said it was (10230703). It is 10230700... what Lunatti calls an improved HP, improved torque, ski-boat, towing cam. Specs are reasonably close to a stock 440 HP cam at:
Thanks all.
