PRHeads
- 10:52 PM
- Aug 31, 2018
- So. Burlington Vt
On a Mopar, when you install the cam so the bottom keyway is at 12 and top gear is at 6(or 12), the cam is advanced 2.5 teeth.
This is about 35*.
Many(most?) builds with a performance cam don’t have enough valve to piston clearance to accommodate the cam being advanced 35*, and if the motor has been run like this, it’s not uncommon to end up with bent intake valves.
If the valves are bent, it will show up on a leak down test.
The motors will run with the cam installed like this, but they don’t run well....... and I have seen it a number of times where they kind of just shut off at high throttle settings as the rpm goes up(3500-4500).
This is about 35*.
