YY1
Did I mention that it runs fine and can be driven for miles and miles?
It will idle for dozens of minutes without stumbling, loading up, stalling or getting hot.
It starts cold on the second or third rotation of the starter, and hot about the same, maybe one more crank.
When driving, it spins the tires easily with no hesitation, and has no flat spots, backfiring etc, when floored.
It does have a moderate surge when holding a steady RPM if you are a bit slower than the gear "want's" to be.
I did have a 1/2 base gasket on it, but replaced it because there was a vacuum leak in that location, and swapping to a new, thinner gasket fixed it.
Book spec timing for a 69 440 is "TDC" for a manual trans, "5 BTDC" for auto, and "7.5 BTDC" for HP version.
(per 1969 "Motor's" manual) Of course idle speed spec is also 750 and 700 respectfully.
I'm pretty sure it does have a cam. It's a lope and not just rough.
