Paul
here's another way to do it
https://www.yellowbullet.com/forum/showthread.php?t=2523879
To get a camshaft recommendation calculated from the CI 2020 software, email the information listed below to
valvemotion@gmail.com.
Send values for bore, stroke, rod length, valve diameters, valve stem diameters, throat diameters (if possible), compression, fuel type,
if Nos give HP Shot, port flow CFM @ .500", .600", Rocker Arm Ratios, Solid or Hydraulic, Desired Peak HP RPM and Maximum or Shift RPM.
The software asks for port flows with intake manifold attached and it calculates the required tuning lengths.
It also calculates the exhaust tuning points.
need to know the Peak HP RPM to calculate the time available to fill the cylinder. You are jacking off without that number.
going to the end Rick can generate intake and exhaust profiles which can be custom ground with CNC grinder
IDK how it would work on a street car but find out
cheers
__________________
