- 3:43 AM
- Jul 1, 2015
That particular carb has an "adjustable" off idle transfer feature, calibrated during the carb's manufacturing, that provides a lean off idle calibration point to reduce emissions, especially during deceleration. There is no real advantage to changing the origional settings. Your problem MAY BE attributable to a stuck in the down position, one or both of the primary metering rod STEP UP PISTONS, which control the position of the metering rods. If the piston(s) are stuck in the down position, the mixture will be lean as the throttle is opened, as the metering rods cannot move up, allowing greater fuel flow thru the metering jets. Remove the covers to check....in the engine off position, the step up piston should be at the top of their bore and move freely up/down. Additionally, there may be dirt or crud in the internal fuel passages restricting fuel flow causing the symptoms noted. Just my opinion of course.....I tried the vacuum advance suggestion but no change, still does the stumble. I will check timing and some of the carb suggestions mentioned next.
BOB RENTON
