They get my vote. People will tell you to "have the balance checked" This is bullshit ... there is no such thing as "checking" balance - you either balance it or you don't. Trust their balance job - they do hundreds of these things.
We use LOTS of 440 Source Stroker Kits, both Customer supplied and when we bring them in for Customers.
The Pre-Balanced Kits
WILL RUN and are acceptable for most applications.... NO doubt about that !
That said...
when we do NOT Check/Adjust the Parts & Check/Adjust/Re-Balance the Kits here....
it can be embarassing for us with Customers present and they ask about the very distinct
vibration we feel on the Dyno Room concrete floor when revv'ing the Engine under load @ rpm ?
Which begs the question when Buying the "pre-Balance Kits ?
How does anybody "Balance" a Rotating Assembly(let be 440 Source or anyone else), and what type of "Balance" Job is it ?
When:
* NO Harmonic Balancer has been attached ?(certainly not the end users anyway)
* NO Timing Gear to
space that Balancer out on the left plane(T-gears can vary up to .030 thickness)
* NO equalization of Piston/Pin weights (just an "average" is used I guess ?)
* NO equalization of Connecting Rod Big Ends or Total(top end) weights (just an "average" is used I guess ?)
* NO Flywheel/Flexplate is attached
It's called "stacking" a bunch of tolerances, a Gram or 3 here.... a Gram or 4 over there.... a Gram or 5
unknown ?... etc., etc
And therein is the what I will call the "misnomer" around the entire concept of Engine Balancing ?
There is Balancing..... and then there is
Balancing....
Spinning Hundreds of Cranks to basically the same Bobweight, or even an "average" bobweight of parts in a particular kit is one type of ...
I GUESS ? "Balancing" ?
just sayin....
IMO, it should NOT be confused with
REAL Balancing of
ALL PARTS and the customers parts
attached, and the long term benefits therein to doing so.
