That's is probably why I was told years ago to throw that away and use the original bracket...
Sounds like it was made either to thin or cheap steel content....
Heck from what you say if you pull the pedal to far towards you that torque alone will bend it...
Exactly, it bends too easy. I was having to re bleed my brakes every few days. Took a look under the dash and the tab was bent out enough to let the piston go too far. Replaced it and solid brakes ever since. I believe it is meant for shipping only, but most of the time the original bracket is missing so it gets used as the stop.
