Hemirunner
4.250 crank and TF240’s ordered today....
I'm planning on doing some posts or videos of Dans 505 Stroker build. I have a spread sheet of most of the costs so far, but still need to buy a few more parts.
On my old 505 stroker, I spent more on the port EFI and Billet Specialities Tru-Track than what the rest of the engine cost. I was suprised when I was able to buy a low mile 6.1L Gen 3 Hemi, with all the accessories, EFI, computer, and NAG1 OD trans for $4,000. I haven't installed the Gen3 yet, been looking at the options and costs for the different swap options, and what transmission controllers will work.
Been there done that and 100% agree which is why I'm still looking for more HP LOL. My current plant has been fantastic but lacks the punch I'm looking for which leads me to the next 2 options in my book, more cubes or boost. Both of these options will gain HP while not hurting it's driveability, if I go with boost it will make more sense to go with a genIII and EFI and obviously a 512 for cubes.My suggestion for builds like this is to cam for the application and how the car will be driven, and don’t get hung up on a horsepower number.
You can take a really sweet running street build and noticeably degrade the street manners by chasing 20-30hp...... that you’d hardly even notice in your 3800lb street/strip car.
The sole purpose of this thread was to see what some of the guys are getting out of their 512's, cam used, street manners, etc.
We’ve done that using Performer heads and a hydraulic roller. The TF heads are significantly better.512-cubes with the TF 270s, will easily make 650-HP with a mild camshaft.
This is exactly the kind of information I've been wanting to see, thanks for posting BadassHemirunnerWe’ve done that using Performer heads and a hydraulic roller. The TF heads are significantly better.
I take that back.... it only made 625 but lots of torque.. with a 6 bbl setup lol. A single 4150 would have made 650 no doubt.
Exactly, I wouldn't even waste my time with a Gen III unless it was a Hellcat, to many upgrades to not take advantage of, it is a purpose built engine.Engine Masters just built a turbo 5.3 LS. Completely stock other than injectors, rods, and pistons. It made 545-HP / 560 ft/lbs of torque. Less than 10# of boost. There is a really valid argument against going to a more modern configuration and adding a twin-screw, turbo, or procharger.
512-cubes with the TF 270s, will easily make 650-HP with a mild camshaft. The glory of the 500-cube Wedge engines is when they can carry that massive flat-torque curve, well past 6,000 RPM.
By the time you go GEN III and add forced induction with the factory EFI, you're better off with the Hellcrate.
This is exactly the kind of information I've been wanting to see, thanks for posting BadassHemirunner. Do you have the cam specs, cfm for the 6 pack?
My big obstacle is selecting the best cam for the job? I'll gladly surrender HP before I give up a reasonable cruising rpm... that's what makes my car so enjoyable to drive, it easily and effortlessly makes long hauls while getting respectable mileage.
Cam was an XR292HR10 installed at 106. Intake was port matched to the heads. Carbs were new MP pieces that we only tuned for WOT jetting.This is exactly the kind of information I've been wanting to see, thanks for posting BadassHemirunner. Do you have the cam specs, cfm for the 6 pack?
Do you have a performance goal in mind, and what is the performance of your current set up?
As a common responded to posts like this, the part that I struggle with is when someone wants 600 hp, or what ever the hp number is. For me, the number is arbitrary unless you plan to run it at the track. Build a motor that will drive the way you want it to drive, and if you want it faster, put nitrous on it.
I get that but when starting a thread where your trying to get input there has to be a measurement as to what your goal is. I've had 350-500ish hp builds and have driven 700hp cars so 600 hp is just a number that I feel would be in the ballpark of what I'm after give or take a bit. I've always built my own engines so not having access to a dyno I rely on research to point me in the right direction, I'm simply looking for input.Do you have a performance goal in mind, and what is the performance of your current set up?
I've got a solid flat tappet in my current build, I don't mind the extra maintenance at all and if there was a very significant advantage to running a roller I wouldn't be against it either but would prefer to stay away from them. I don't like the idea of having shrapnel all through the engine if one fails.Okay. Would you be okay with a solid flat tappet or solid roller, and would the say, 30 or 40 hp advantage be worth it to you? how many miles will you drive a year?
On a good year I put 4,000 miles on it, mostly within 1 hour drives but have taken quite a few 12 hour round trips.
