What's it Worth 68 coronet rt convertible
Bennoel 10
10:52 PM
Toronto
Wondering on what the membership thinks...
68 coronet rt convert is worth. Auto console. I believe original drivetrain. Has had a repaint and bodywork. Northern car all its life, meaning used as a car in the rust belt in its early years maybe not so much after a decade or so. Just guessing
Been off the road for a good while but runs, steers, stops and drives. Needs exhaust for sure. Top goes up and down with no issues. Lights work. All there that I could see on a first look.
I dunno, looks like a nice car in good colours though that could be driven as is.
For sure it could be driven as is after it's been given a mechanical inspection and necessary repairs completed. It has no exhaust at present other than head pipes. My concern is what's underneath ?. I did look at the underside and it's lathered with heavy grease. Appears to have been applied many many times over the years. I was allowed to scrape off some but understandably not extensively. Where scraped off looked good. Obviously in the corners and tight spots is my concern. It's what I can't see that concerns me. So with it being a convertible and low numbers and a running driving car, not a show piece and not a complete project where does the value fall ???
The top well is suspect and the Dutchman panel. If you look up inside the trunk hinges look for blisters and rot, the rest is normal stuff... what is it worth is all up to you!
