Mstone68440RR
I haven't had any time until this week to work on getting the car started since the issue I had with it dying on the road a fe w onths back.
Things I have done so far to try and fix it are,
Bulkhead connections checked, cleaned no visible signs of overheated terminals or melting wires. A few pins had light corrosion starting, but not bad.
Ammeter bypass at dash, again terminals and posts looked fine.
New MSD 6 A and blaster 2 coil installed and just verified system is in working order and providing spark.
Cap, rotor plugs and plug wires are new with less than 200 miles on them.
Distributor cap off, rotor turns when cranking.
Grounds checked and cleaned and reconnected.
Fuel pump working fine, fuel squirts with accelerator.
Battery tested and fully charged
Car turns over but still will not start. I have searched this issue on FBBO and think I have tried most of the past common issues that others have experienced, but I still feel I am overlooking something simple. I did just notice that the yellow wire coming from the starter relay isn't in great shape, so I will try to replace that this afternoon when I get back home.
I am open to any other suggestions as to what else I should be looking for, thanks in advance.
Mark
Mark
