It's been nearly two years since I've stuck my nose back in my own build thread. Stinks that the forum won't let me edit the old posts, as I'd fix all those dead TinyPic pictures. How about it, mods?
I'll post some photos over the weekend, but here's a bit of an update for those of you who don't mind text walls:
- The ignition remained an issue when I let the thread die in 2019.
- Not mentioned here is that shortly after going back to manual brakes, the front reservoir on the master cylinder (rear drums) started losing fluid regularly. Eventually, it drained dry and that was enough for me to walk away from the green pile for a while. Went back to tinkering with my vintage bicycles (and also started a museum for retired shared bicycles, and have since preserved quite a few).
- The alternator was dead.
First of all, the ignition issue has been nipped in the bud.
No, I didn't get it on the first fix, but the sum of the work fixed a couple of small issues along the way.
IGNITION:
I took apart the distributor (minus the shaft). I found the centrifugal weights and plate were sticking a bit - not enough to prevent the distributor from working, but enough to explain why sometimes the RPMs would be a second or two slow to come back to idle (in park) if one blipped the throttle. I cleaned up all the surfaces and coated all the friction surfaces with 00 grease. The "you must own a Snapper!" 00 grease is what I keep around for internally geared Sturmey-Archer bicycle hubs, and I knew from experience that this grease does marvels in places like this. It has the lubricity of oil and the stickiness of a grease.
Sure enough, once that DAMN CIRCLIP (you know what I mean if you've been here) was back in, the whole mechanism moved like it had never moved before.
Also, I dumped the hodgepodge of plug wires I had on the car
and the female-terminal distributor cap. On went the de-facto Summit Racing male terminal cap, which - besides taking care of the lousy fit of the old connectors (if you yanked a wire by chance, there was a good possibility a wire would pop off the dizzy cap) - feels like a proper, thick casting of plastic. The way you expect a distributor cap to feel.
So as not to fight the factory valve cover wire guides, I used the Pertronix FlameThrower "factory look" 7mm wires to clean up the mis-matcho of wires that were under there. Importantly, they claim their wires support HEI, and since I was going 7mm, I felt it was worth the extra cost to make sure I wasn't winding up with cheap-core parts store wires. Plus, it gave me an excuse to cut each wire to a length that I'd be happy with.
I threw it all on. Even with a carb obviously full of junk from sitting, there was an obvious improvement in idle from before (and the delayed RPM drop was gone). Nevertheless, it still occasionally went dead for no reason.
Though I could have taken
@Billccm's very detailed advice here and troubleshooted the HEI module, I just went for the "blunt fix" approach, or "do everything you should have done in the first place, dummy" approach, as follows:
- I deleted the "for looks" ballast resistor (I had soldered a huge wire from tab to tab)
- I put an extra ground strap between the engine block and the firewall
- I put a ground strap on the HEI module where it attaches to the Designed2Drive adapter
- I re-wired the entire HEI ignition harness with a relay.
This was fairly involved, and I chose to use
this particular relay, as it has Weather Pack-style sealing on the connector. Doesn't bother me one bit that it looks modern and is Chinesium. It happens to be
good Chinesium, not some stamped steel-and-fiberboard Tonka toy relay from the 1970's.
I followed this fairly simple schematic that's been floating around on FABO:
One error that 67dart273 pointed out: "To coil brown wire" is supposed to reference the switched ignition coming off the now-deleted ballast resistor - both Ignition #1 and #2. They got soldered inline before reaching pin 86.
After a fair amount of soldering and heat shrink tubing later (a real pain to do once you're at the point where you must crawl up to the back of the firewall to finish it), the new relay-switched 12V ignition was ready.
Instant start, with an
obvious improvement in overall idle, even with the carb full of junk.
Long story short, I gave the Edlebrock a thorough cleaning - didn't even need to replace any gaskets - re-adjusted the floats perfectly, plopped it on, and for the very first time, heard this 360 idle like a MPFI Magnum on the showroom floor.
There are some times when you
know you've solved a problem, and this was one of those times. Even then, I went ahead and did a few start cycles with it randomly over the day and next week. Absolutely zero issues with the ignition dying on a whim.
Was it the relay that fixed it? Ground straps? Deleting the not-a-ballast-resistor? Frankly, I think it was providing clean 12V via the relay that did it, but I can't say for sure that it wasn't the ground straps either. Personally, I think it's the wrong question to ask - it just makes sense to do all three for reliability.
BRAKES:
I decided I'd had enough of these rebuilt steel master cylinders. Every single one I've had has leaked out the top, and the last one decided to leak out the back.
Hell with that, I said, and bought a later aluminum master cylinder,
Dorman M99294, cross-referenced for a 1985 Dodge Diplomat. 1.03" bore. And
yes, it has the all-important groove for the rubber grommet that holds the drum-brake pedal rod in place. Amazon had one for $31.92, so I jumped on it. (Price is now $44.44 at the moment, so sometimes it pays to wait around and watch the price). It has the black reservoir, despite the pic.
As many have discovered (even those who have bought from Cass), the factory plastic reservoir caps that come on these aluminum M-body masters are warped junk. The rest of the master is good quality, the caps simply are not. I tossed the caps and bought a pair of
Dorman 42053's to replace them. They're a completely different casting, despite also being a Dorman product. Yes, they're a mustardy yellow, not black, and I couldn't care less - they
work.
I paired the master with
Dr. Diff's adapter plate, and said BYE BYE (or if you have a Road Runner, "MEEP MEEP!") to ever having to tighten those blasted master cylinder bolts under the dash. Seriously, the placement of the master cylinder fittings on these cars belongs right up on the Top 10 list of Mopar Cluckups.
I also pulled the rear drums, replaced the rear brake line with an Inline Tube replacement (didn't have any leaks, Bill, but I made it a point to tighten/retighten multiple times to get the flares to seat) and replaced the rear wheel cylinders...again. Actually had to do this twice, as I put Raybestos WC37053's - OEM spec for a '68 Satellite - in there first, and then WC36235's for a 1985 Diplomat.
The first time around, I couldn't get a pedal except for the last inch of travel, and couldn't seem to get air out of the front brakes. I have a (bullshyte) theory that this is because WC37053's were designed for the factory drum check valve on the master cylinder - no longer present - and, as such, was allowing too much fluid to be pumped to the back before engaging the front brakes. More likely, I didn't have the pads set perfectly, and said air pocket was causing the master at the piston to travel too far before pushing enough fluid.
At any rate, I put the WC36235's on and decided to give one of those Motive Products pressure brake bleeders (Model 0103 for the later-style master cylinder) a try.
Opened the bleeders in the usual way (farthest corner to nearest), and not only did the Motive bleeder work, it worked so well that I didn't even need to do any bleeding at the pedal (FYI - I installed one-person bleeders in front on the FMJ style calipers. I used
Russell 639590's). I know my experience probably doesn't speak for all B-bodies of this generation, but this gave me so much trouble that I'm half convinced that there's something in the design of the B-body brake system that makes it very difficult to get air out of a particular spot in the system.
Note to self: Pressure brake bleeders work
goooood on these later master cylinders.
This said, I finally have
properly working manual brakes after all the effort. They feel good. Just a
wee bit on the spongy side in terms of feel (in comparison to a few other manual brakes I've used), but very modulatable, responsive, and they will lock if you ask it of them. Just what you'd expect of a mid-size passenger vehicle, provided you are not thinking about how a pedal feels with vacuum assist. I'm not disappointed that I didn't spring for the smaller, 7/8" bore either.
ALTERNATOR:
Quick fix for the alternator was to slap the '62 Lancer alternator - the one the car had when it arrived here in the first place - on it. Go figure; the squareback failed, and the earlier one worked.
FINAL THOUGHTS:
The Satellite works so well now that I actually have confidence in the thing not to Roadkill me on the side of the road. It idles and gives the confidence of a vehicle with MPFI. I want to say "it feels almost modern," but then I remember the rattles and bangs of the interior (still no headliner or sound deadening in it), the ridiculous bench seat (it feels as if you need a 4-point harness just to stay put in it, and you're still sitting in a hole despite its puffiness), and the
piece of **** steering box that'll cost $450 to upgrade with Firm Feel (there's an additional charge for setting the box for the fast-action Challenger/C-body pitman arms)...
Moral of the story? Spend the effort to get the small stuff right, don't cheapen out, and treat your brake system out
as a system.
Pics soon.
-Kurt
