So, here is what I have found.....
My deck lid lip overhangs the metal by a consistent 1/4 inch and when I put the chrome trim on, and lay a straight edge across the lip of the deck lid, I find that the trim is slightly in from the lip (1/16 - 1/8)
So this pic show left side because my trim is slightly bent on the right side and I could not get good measurements.
The two small pieces of tape mark where the screws are that hold the trim.
The outer screw hole was welded up but the eye brow trim is holding it tight against the metal.
Starting at the left
straight edge is touching the trim and lip so right here it is in line
In about 8" over the screw holding down the trim
here you can see the lip is overhanging the trim
And in another 8" right over the screw
And here again you can tell that the lip is overhanging the trim
So, here is what I am thinking.........
To get this problem resolved, whether or not my tail panel is positioned in the right spot or not (I think that overall I am close) I think I need to massage the metal under the extensions closing the gap.
Now how to go about that......... I am gonna have to think on that..... which is where I will need some more help!
What do you guys think?
