Well got a little more work done on the GTX over the weekend. First finished up the front brake lines.
I still need to install the proportioning valve. Anyone have a favorite place to put one. I was thinking the line between the MC & distribution block. So it'd be easy to set.
I also got the fuel lines ran to the back.
I used compression fittings to make the sharp corner through the sub frame connector for the main line. It was going to be too tight to get the return line through the same hole so I angled it through to the other side of the connector.
Had to do some work back by the wheelwell. With it being mini tubbed there wasn't room to run it behind the lip of the inner wheeltub.
I've got it tucked tight against the well but not sure if this will be Strip legal. I may have to revisit this....
I put the 3" tail pipe up in there to see how it fit. Tight but clears everything. This is the view from the back.
This from the front. I ordered 3 ft of heat shield sheath to help protect the fuel lines from heat from the exhaust pipe.
I also worked on the carbs a little. I needed to re jet the carbs after I got it home from Jim's shop. His shop was at 5000' ft altitude and I'm at 1000'. So according to Holley I need to increase 1 jet size for every 2000', so 2 jet sizes it will be for starters. I pulled the carbs apart and documented the jets.
Here is where it was at. Looking at the carbs from the front of the engine and left side being pass. side.
rear carb
L R
92/89
center carb
62/62
front carb
89/94
Also I have a quick fuel metering block on the center carb. It has a 5.5 PV with 49 jets underneath. Idle restriction jets 28
Emulsion jets 28 (3x) I'm going to leave those as is for now till I can get the car on the road. With the help of the LM-2 I can get these dialed in. I will have a O2 sensor on each side to help tune also. Hopefully this will help me get it dialed in fairly easy.
