- 2:25 AM
- Oct 16, 2013
- Kiel Germany (back again)
Go for it. What a great car. As others have said, dont let moss grow under your feet.
welp we are proud owners of a 69 RR!!! got it for 5500$ looking forward to getting it in our garage and seeing what we got. how hard is it to find a front bench seat for them? do you have to get one out of a 69 or are they the same through so many years??
Sure hope you are right.Numbers matching are hard to find these days and are worth a ton when you find them.
Roads64, if this is truly a "numbers matching" car I would take it back to factory. Numbers matching are hard to find these days and are worth a ton when you find them. Good luck with the project! Looking forward to watching it go together
Yup used a 66-67 Satelite seat. Legendary covers fit, only issue is the mounting studs are about a half inch off. Not a big deal for Me.I believe you will find 68-70 bench seats interchange with only seat pattern being different. And maybe the latches and covers on the side varying slightly as well. Other than that they should bolt right into the same holes as the floorpan is the same. 66-67 may even fit too.
