727 kickdown linkage
Napoleon1991
3:49 PM
illinois
Hi, I'm looking to get some information on the factory style 727 kickdown linkage for a 65 coronet with a big block. I really don't like the gritty feeling Lokar trans cable setup that's currently on my car, and I want to go to a stock style linkage. I'm not sure what to look for since there's so many different types of linkages out there. I've found numerous diagrams but they all seem to be a little different. Is it a 1 piece or a 3 piece rod that I need? I also need help determining the types of brackets required as well. Would really appreciate someone pointing me in the right direction.
I've gotten two different kickdown setups, emergency brake setup, brake pedals, etc. from this eBay seller. He had all of the strange clips for the linkage that I could not find or everyone was out of stock already installed on his setups. You can actually call him and he can see what you need -- he refurbishes things and resells. Not cheap at all but everything I've gotten works perfectly. Called Norms Speed Shop and the link is here:
| eBay
Kickdown linkage for '62-'65 727 is a single rod that hooks to carb linkage at one end and the kickdown lever at the other. There is a bracket that mounts to one of the end intake bolts, that resembles a couple of fingers that guides this rod. Try [email protected] for this.
My car originally had a 318 in it before I swapped in the 440. I kept the one piece kickdown rod, but I wasn’t sure if the same rod was used for both big and small blocks. Unfortunately I don’t have the bracket that guides the rod anymore.
I should also clarify that I really don’t care if it’s factory correct or not for a 65. I just want an original style system that works because Im not too satisfied with the cable. Will the kickdown linkage from any year fit?
The 67 wagon I added to the stable has Lokar kd and throttle. The brackets are super flimsy, can't get kd which I think is from brackets flexing and full throttle due to ratios between them being off. I'm going to get the throttle cable bracket that AR Engineering makes to fit the Performer Rpm manifold plus get a repro throttle cable and Andy says to use the 3 piece kd unit[ rods, bell cranks, adjusters etc]. I'm in touch with a guy to see if he has some in his stash. Try for some trading with stuff I don't need. There are some reproduction kd packages out there but are very pricey.
Try A and A transmissions. They have what you are looking for. Call them......they make all kinds of parts for the 727 transmission.....an excellent source of information.....just my opinion.....
BOB RENTON
Contact Us​
Mm!Hours: Monday-Friday 8:00 AM - 5:30 PM EDT.
Technical Advice: Available by calling (317) 831-5610 Monday - Thursday, between the hours of 4:00 PM - 6:00 PM EDT, faxing (317) 831-9710, emailing us at [email protected] or writing to A&A Transmission, 5061 E N County Line Road, Camby, IN 46113.
A&A Transmissions
Camby, IN 46113
(317) 831-3066
The newer '66-'70 articulated pieces should work as well, as long as you get all the pieces, including the kickdown lever. There are different length levers, depending on style of kickdown.
Just following up with this in case anyone else is interested or having the same problem. I finally pieced together brackets out of a New Yorker and a kickdown rod from a Cordoba and it works perfectly! Much cheaper than other alternatives I've seen for sale. Thanks again everyone for your help and suggestions.
Got any pics?
I’m doing the same swap.
65 satellite 273 to 440
Got mine in a week ago. Works great. Pieced the KD unit together. Sourced the three rods through friends, thanks guys, then bought the needed bell cranks and trans arm from Mancini. Also from Mancini I bought a stock style throttle cable, the AR Engineering cable/kd bracket of the Eddy manifold, the adaptor arm for a Holley to fit Mopar applications. The PO had used the generic, junk cable stuff there too. Now I have full throttle, 1/4 throttle before, and KD action. Here is a diagram of what I sourced from carb to trans. Used from #1 to #11 in the diagram. A&A trans, Laysons and some others have complete KD packages but they are expensive.
