So I ran through the gears at idle to make the TQ was purged of any air, I removed the drive belts and ran the motor. Both produced no change.
Pulled the motor and took the crank, HB, flex plate and TQ back to the machine shop. They tried to re-balance using Bob weight from the original weight card. Heres what did not seem correct, when spinning the crank with everything mounted the TQ wobbled, thet tells me and we confirmed the flex plate was bent. We ordered a replacement. Also the readings on the front of the crank stayed steady at 11.6 grams the back fluctuated by 20 gram up and down when tested multiple times. Having researched a bunch of research, I found a note in a mopar balance article the said only balance the crank, HB and flex plate not to include th TQ, others say include the TQ with a stator lock (which they were using) and another that said cut a used 340TQ in half and remove the guts and balance with it.
So what is the correct process. Any thoughts?
Flex plate arrives tomorrow and they are going to see if the wobble goes away, then we will take it from there.
Thx
