Mattiep
Ok guys i know the 400 smog motors aren't very popular for performance. i have a complete freshened up bottom end. plan to use in my 64 savoy, only heads i have are 906 heads, i'm wanting to bump the compression up a bit, i know the 73 400 was 8.2:1 is it even possible to get it up close to 10:1 by shaving the heads? the cam i would like to use clearly states 10:1-11:1 comp when i was putting the motor back together i couldn't find any off shelf 400 high compression pistons with out being for a stroker setup. what would you guys recommend, vs how much can i shave off these heads safely with out destroying them.
