If untouched, it will have a tag on one of the bolts for ratio and another round tag for SG.
If neither exist then try this:
trans in neutral, one tire off the ground..can you turn the tire? Yes = open carrier.
with both tires off the ground, put a mark on the tire and a matching mark on the ground/spring/something...now turn the drive shaft by hand. How many driveshaft revs for one tire rev?
