- 12:34 AM
- Sep 5, 2017
- 6720 Cuff Road Jackson, MI 49201
Back at it again. Transferred the main body line to the right side and outlined it in black. Then I went back to the left side and patterned the secondary body lines fore and aft of the wheel arch. Highlighted these in light grey. Once highlighted I can see how far off the PO left the bodywork. I originally thought this would only take about 3 hours to bend but now it is looking to be closer to 6 hours or so as I don't think the stud welder/puller will do it all. Probably have to pull the interior panel off and start smacking it from the inside while my assistant (wife) holds the dolly on the outside. This should make for some entertainment. I would have taken off the inner panel anyway as when the all the holes are welded in I would want to make sure nothing got set on fire. I always use the 1/2 hour rule but a lot of damage can happen by the time you see smoke.
